MF1100 lost high range
JaredM
01-24-2007 14:49:47
I was going to put off fixin it since I had my 4020 to do the work since last spring but then my boss just picked up a cab w/AC compressor etc. for me for $200 and now I need to find out what is wrong. I was not on the tractor when it happened but it just slipped out of high range going down the road and won't go back in. Low range and multipower are both functional on the tractor. What could be the cause of this it pushes back when you get close to the high range setting. Any ideas of what might be wrong would be helpful. Thanks. JaredM
JaredM
01-25-2007 05:37:33
 Re: MF1100 lost high range in reply to JaredM, 01-24-2007 14:49:47
Thanks Tom I'll give that a try this weekend. Jared
tom poplett
01-24-2007 15:03:57
i had an 1100 that did the same thing and a buddy of mine told me to open the area under the steering wheel and lubricate the linkage.i cleaned around it and lubricted and everything worked fine after that.
