Lead substitute for nolead gas
Ralr from MI
01-22-2007 17:44:19
read some place where you can put lead shot in the gas tank for old engines. Has anyone ever heard of this ? Does anyone have something else they use ? thanks
Brucec
02-01-2007 10:06:36
 Re: Lead substitute for nolead gas in reply to Ralr from MI, 01-22-2007 17:44:19
STP sells a lead substitute available at NAPA When I tried it in my MF202 I thought it quieted it down. Probably just my imagination but it didn"t cost much so it seems worthwhile.
john d g
01-23-2007 09:55:13
the old engines run just fine without adding anything-----if u must, do as i do and add a handful of lead shot in the gas tank (use the big balls - buy them at K-Mart, use the ones for powder muskets- there large and won"t clogg anything---they disolve extremly slow- and as there rolling around in the bottom of the tank prevent rust from forming----good luck---john
mike a. tenn.
01-23-2007 04:17:56
you can buy a lead substitute gas additive, and i've been told that a little transmission fluid in the gas can also work to help lube the valves and whatever. i don't know how well either of these work, if at all. what about "marvel mystery oil"? (if you've ever heard of it) i know that it's s'pose to lube the upper cyls. and heads...tho i've never tried it in my tractor i used to use it all the time in my car.
Gerald J.
01-22-2007 21:52:20
You can toss bbs into the tank. Won't affect the fuel though they might tend to clog the screen. The "lead" in fuel was Tetraethyl Lead a liquid. It may have deposited something like metalic lead when burned.
But if you aren't running the vintage engine pulling a plow 500 hours a year, you aren't going to cause significant valve wear and with using unleaded fuel you also won't be fouling plugs or the air you breathe. Lead ingested has a tendency to kill brain cells.
Gerald J.
