165 ignition timing
JAT
01-22-2007 07:05:30
I have a 165 with a Continental engine. I just replaced plugs, plug wires, points, condensor, rotor, cap, coil, and carburetor. The ignition timing was very erratic so I pulled the distributor and found that there was about 1/8 inch up and down play in it. I don't know how much there should be but I put a shim in it anyway to see if it would help. The distributor gear is not worn very much.
Still the timing is erratic. At idle it jumps between TDC and 15 degrees and at high RPM I can't even read it. Could this be the advance springs or weights?
I'm thinking about ordering a new distributor but wanted to get someones opinion before spending $250 on something I may not need.
Thanks.
Jerry/MT
01-22-2007 21:24:50
 Re: 165 ignition timing in reply to JAT, 01-22-2007 07:05:30
Take the distributor to an auto electric place that works on these old distributors. Your shaft and/or bushing are probably worn out. Push radially on the shaft and see if there is any side play. The limits are usually around 0.002".
A good auto electric shop should be able to rebuild the distributor and check the advance mechanism, etc. I had an outfit in Portland, OR do mine for $100.
