perkins 248
massey fan
01-20-2007 08:40:51
hi,i have been to look at 2 tractors with perkins 248 desiels this week,both have oil weeping into the exhaust,they both started very well.but one is very smooky when pulling hard and missing alittle.what are the causes of this? is it any thing to worry about? thanks
DavidP, South Wales
01-20-2007 14:51:35
 Re: perkins 248 in reply to massey fan, 01-20-2007 08:40:51
Hi, I assume the hours are quite high. Look at the worst situation. Worn valve guides and or valves, seizes oil scraper ring/s, worn bores.
How much 'blow back' is there? Pressure in the sump?
You would need to remove the head to find the problem. A compression test may help but it would not be conclusive for this problem.
DavidP
massey fan
01-21-2007 04:37:51
 Re: perkins 248 in reply to DavidP, South Wales, 01-20-2007 14:51:35
hi david,one has done 4500 hours,doent breath at all but is the worst starter.the other is 7000 hours (fitted with hedge cutter for 20 years)starts instantly just breaths slightly out of breather pipe not dipstick,but runs smokey.i think it is probably valves,do these early 248s have valve guides or do you fit valves with oversized stems? thanks
DavidP, South Wales
01-21-2007 05:20:28
 Re: perkins 248 in reply to massey fan, 01-21-2007 04:37:51
Hello,
My information shows that all 248 engines are fitted with valve guides.
DavidP
