Another 444 ?
Dale L
01-18-2007 16:01:44
I have a question that maybe someone with 444 experiance can answer. I dissasembled the live pto clutch and brakes on a 444 and it looks like I'm going to have to replace all 5 seals on the differental.The problem is there is side to side play on shafts in the bearing carriers.If I remove equal amount of shims on both sides of the tractor will the backlash on the differental stay thew same or change? I don't want throw every thing else out of wack. The repair manual I have isn't the best. Any advice is always appreciated. Thank's Dale
A Suggestion ......
01-20-2007 06:02:12
 Re: Another 444 ? in reply to Dale L, 01-18-2007 16:01:44
Post your question again only this time make the title read ...."Question For Harris Guy". He hangs around the forum here and should be able to answer it for you. I'm suprised he hasn't done so already.
