Pump driveshaft won't move forward for belt change
gary in Mt. Dor
01-17-2007 11:34:46
Bolts are loose, plate is loose and wobbles, but won"t move forward.
Don-Wi
01-19-2007 16:10:18
 Re: Pump driveshaft won't move forward for belt ch in reply to gary in Mt. Dora, 01-17-2007 11:34:46
What model is this?
Some shafts are threaded into drive hub bolted to the crank. Bolt it back on, and try turning it with normal direction of engine rotation with a pipe wrench.
Of coarse, if you can clearly see the ends of the splines (should be able to if they are in fact splined), or if you can see a key way in the shaft, (again, you should be able to see the end of the key way) you will have to pull like crazy if it's not coming out.
My guess is that it's a threaded drive shaft and hub.
Donovan from Wisconsin
