mf65
ken lyles
01-16-2007 19:36:44
Two questions:
lost my dad in oct. i have his 58 model mf65 that he bought new. so question 1. power stering is easy to the right, and takes three arms and four legs to turn it left. please walk me through the adjustment linkage..... .....
2. if i replace the generator that hasn't worked in twenty years with an alternator, what about the gear drive tach that hasn't worked in thirty years?
thanks
DavidP, South Wales
01-17-2007 01:27:34
 Re: mf65 in reply to ken lyles, 01-16-2007 19:36:44
Hello,
Aaron below, is correct about the turnbuckle but I would add a bit more.
There must be no play in the turnbuckle pins and wear in other parts of the whole system must be at a minimum. The power steering works by actuating the system in the initial movement of the steering wheel from it's centre position. If this movement is lost due to wear then you will be turning the wheel manually before the power takes over. If you have wear in the pins or yokes a good machine shop should be able to drill them out and fit larger pins. Have someone turn the wheel with the engine stopped. Look inside the front grill and my guessis that you will see the rod end of the ram moving up and down in the casting. This alone is enough to kill assistance in one direction. As long as you can remove the pin, it is possible to put some packing in to stop this.
Other places to look for wear are;
Excessive play between the steering wheel and drop arm from the box, adjustable.
Play in the ends of the drag link
Play in the ends of ball joints at the axle.
Wear in the bushes and shaft that goes through the front casting.
Excessive play in the tapered pin adjustment.
Play in the turnbuckle connection arm on top of the shaft.
If your system is in good condition ALL ROUND, carry out the following adjustment. Disconnect the turnbuckle. You will see a large nut with a screw in the middle with a straight slot. Slacken the nut and turn the screw down until it just goes tight. Adjust the turnbuckle so that the pins just fit. Undo the screw SEVEN turns and nip the nut. This gives you an initial setting. Test the steering under power and if you think it can be improved undo the screw HALF a TURN at a time until you reach the best point, but don't go to far. Ideally you should have 'one finger' operation of the wheel but you will have to make allowance for wear in the pump etc.
Please let us know how you get on.
Regards
DavidP
TomTX
01-16-2007 21:08:36
You can have the generator rebuilt pretty reasonable. After the gen rebuild, then trouble shoot the tach. I would keep it as original; cobbled up tractors are a dime a dozen. Tom
Aaron Ford
01-16-2007 20:23:14
Gonna do my best here. There is a turnbuckle behind the grill that engages the control valve. The holes in these get elongated and cause stiff steering. I suppose the adjustment could be placed in the center of the slack. This may work, or it may cause it not to work in either direction. I would try to manually engage the control valve while someone else is turning the wheel to see if it kicks in. Might be a control valve issue.
About the Tach,
There was a company making conversion kits for about $200US. I have not heard from them in a while. I am posting a link to the Tach I am going to use with my alternator swap. It is the VDO 333-353. 4000 rpm w/hourmeter. Should look good with my other VDO Series 1 gauges.
HTH
Let's go Mountaineers,
Aaron
