MF 135 Valve Cover - Torque
Keith Craig
01-16-2007 18:12:38
I'm replacing the valve cover gasket on my 1970 MF 135 (Perkins 3 cyl) - does anyone what the torque value is for this? Great forum - thanks for any reply.
DavidP, South Wales
01-17-2007 01:31:29
 Re: MF 135 Valve Cover - Torque in reply to Keith Craig, 01-16-2007 18:12:38
Hello,
A 5/16 unf nut would have a torque figure of around 25 lb.ft. You are likely to damage to cover at this figure. Ensure that you have a fibre washer of some sort under the metal washer and and tighten carefully until the cork gasket just begins to compress. Assuming the gasket is fitted correctly you should not have any problems.
DavidP
