8 ft MH off-set disk, need advice replacing blades
LWP
01-15-2007 15:49:48
My dad gave me his Massey Harris disk. The blades need replacing and he told me the gang shafts are oil lubricated with oil seals?
Is this correct? Any advice?
Any good ideas where to get blades and oil seals (if it has them)?
This disk is offset, about 8 feet wide, has 22 blades, eleven in the front, eleven in the back. The back blades are about 22" across, the front blades are 17", hard to tell because they're worn and corroded from sitting on the ground. He bought parts and blades from our local MF dealer about 25 years ago but they're out of business.
The steel frame is in great shape and it worked great in his cow-calf operation so I would like to use it in my pasture.
thanks,
Louis
