MF 135 PTO problem
Dennis
08-30-2000 19:28:18
I have a MF 135 gas that I use mainly for blade work. This summer I hooked up my 3-pt. Brush Hog mower, but when I engage the PTO, I get a clacking sound and the mower won't turn. If I disconnect the mower, the PTO shaft turns freely. I greased all the mower fittings and it seems to turn freely.
Bill
09-03-2000 21:06:09
 Re: MF 135 PTO problem in reply to Dennis, 08-30-2000 19:28:18
Hi, PULL THE INSPECTION COVER ON THE BOTTOM OF THE TRANSMISSION. IF THE NOISE IS COMING OUT OF HERE YOU PROBABLE HAVE A BAD PTO SPLINE ON THE END OF THE TRANSMISSION GOING TO THE CLUTCH.
B.C.
08-31-2000 10:54:49
Did you pull up or down to engage the PTO? Lots of MF's had ground drive down, neutral middle, and engine PTO up.
