flat top fenders on US 135
Archie in ky
01-14-2007 04:25:10
Did the US 135 come with flat top fenders aqnd if so what year.How do you do a comp. test on a diearl engine? Thanks Archie
MF Poor
01-14-2007 05:19:29
 Re: flat top fenders on US 135 in reply to Archie in ky, 01-14-2007 04:25:10
Flattop fenders (w/ dual headlights) were available as an option on US market 135's throughout their entire production run.
(I'm looking through 135 sales brochures from 1966 and 1972 at the moment.)
DavidP, South Wales
01-14-2007 09:17:00
 Re: flat top fenders on US 135 in reply to MF Poor, 01-14-2007 05:19:29
Hi, to carry out a compression test you will need a Compression Test Kit for a diesel engine with the correct fittings for the injector fitted to the MF 135. When you are set up with all injectors removed, check one at a time. An ideal pressure is around 150psi but 120-130 are often OK.
The actual pressure is not so important as the three being similar. One wild one will loose you a lot of power.
DavidP
Bert C.A.
01-14-2007 10:57:50
 Re: flat top fenders on US 135 in reply to DavidP, South Wales, 01-14-2007 09:17:00
Hi
I'm wondering....
Gas AG3-152 engine
7.5 to 1 compression rate = 150 PSI
(stated in service manual)
Diesel AD3-152 18.5 to 1 compression rate = ? PSI
(Not stated in service manual)
Should we attempt to measure compression on a diesel engine with a gas engine compression
tester ? ...will it explode and cause injuries ?
When starting a diesel engine how many PSI are required
to ignite fuel in combustion chamber @ 70�F (21�C) ?
Thanks in advance
Bert
Ken Lyles
01-16-2007 19:23:50
 Re: flat top fenders on US 135 in reply to Bert C.A., 01-14-2007 10:57:50
Where can a person find a set of flat top fenders?
