265 Remote Valve Problem
TN Ford Farmer
01-13-2007 11:05:27
Neighbor has a 265 with 2 remotes. Lifting the rear lift arms caused a hose to be unplugged from the holder. After replacing the hose one side of the remote doesn't work as before. It seems you have to hold the lever back real hard to get it to work. We tore the valve down (not an easy job) and found a little piece of rubber in the switching valve.Cleaned,reassembled, installed on the tractor and still same problem. What should we look for? Any suggestions as to how to fix? Thanks!!
