MF65 help
Gary Shortslef
08-30-2000 18:17:38
Am getting diesel fuel into the oil base don't know where to start
David
09-02-2000 21:14:40
 Re: MF65 help in reply to Gary Shortslef, 08-30-2000 18:17:38
Your problem could also be in the lift pump (the little cam operated pump that delivers fuel from the tank to the injection pump) You can take that pump off and check the inside to see if diesel is present around the operating lever. Just a thought, David.
Jack in NB
09-01-2000 04:53:01
Hi Gary -
Mine leaked when I got it in '78. Allowing for seniors moments, I seem to recall an o-ring inside the female socket in the drive of the injector pump.
Doesn't show in the parts book, and not mentioned in the I&T manual. And I can't remember size.
There are two different pumps in the regular injection engine in the 65 parts book (before and after s/n 677170), and a different one in the direct injection engine.
Mine is 678... - the middle one. The configurations of the other units do not look as if they accept o-rings internally in the drive.
Hollar for Big Dean - he may have a better memory!
fergi
08-31-2000 16:57:04
some models have a seal on the front of the injector pump, if that seal starts leaking it will put the diesel into the engine oil, CAV pumps are prone to this I've read
