MF 135 power adjusted wheels
Herb J.
01-13-2007 07:24:11
We just bought a MF 135 and have a question about the power adjusted wheels.
After removal of rim stops, is there anything else that holds the wheel tight before making the adjustment? On a T0-35, there are eccentric screws that need to also be loosened but these are not on the 135 wheels. Want to make sure before doing something foolish.
MF Poor
01-13-2007 09:30:12
 Re: MF 135 power adjusted wheels in reply to Herb J., 01-13-2007 07:24:11
Yes there is. The 4 bigger bolts that hold the spin-out brackets to the center dish need to be loosened. They wedge themselves tight against the rails when tightened. Loosen them about 3 or 4 full turns each. That'll let the rims move with little effort.
HerbJ
01-24-2007 03:49:49
 Re: MF 135 power adjusted wheels in reply to MF Poor, 01-13-2007 09:30:12
Thanks. Suggestions worked like a charm!
MF Poor
01-13-2007 10:20:28
I just thumbed through parts books for spin-outs on 30's 35's 40's 50's 65's, 135's and 150's. I found 4 different styles. I still believe your 135 will be like my 150. (Described in above post)
DavidP, South Wales
01-13-2007 11:30:36
 Re: MF 135 power adjusted wheels in reply to MF Poor , 01-13-2007 10:20:28
Make sure that the sliding clamps and their bolts are free. They must slide outwards to locate against the square spiral on the wheel rim.
Check regularly fot tightness of wheel.
