Ferguson F-40 hi crop
mike smith
01-10-2007 04:18:59
Hello again it's me the guy with the mystery ferguson. Now that I know I have a F-40 hi crop I was woundering if anyone can provide me with additional info such as production numbers and any additional info that you can think of. thanks again.
Paul in AZ
01-10-2007 09:05:33
 Re: Ferguson F-40 hi crop in reply to mike smith, 01-10-2007 04:18:59
Mike,
3,427 of the F-40s were built in 1957. I know of no existing records as to how many of each of the four chassis configurations were built.
The F-40 was adapted from the TO-35. The primary mechanical differences were the front axle configurations, steering systems, and the ability to use other than rear-mounted implements.
Today the F-40 is a very popular model for Ferguson collectors and restorers. Many parts are quite readily available, including new grills and chin pieces.
You may wish to access the YT Harry Ferguson web site.
You may also wish to log onto the following web site for additional information about Ferguson tractors, including correct paint color codes and paint schemes, SN informtion, wiring diagrams, Ferguson tractor shows, etc.
Dean Thornton
01-10-2007 08:46:29
Hi, I have a 1957 F40 that Daddy bought new 3-13-1957. My tractor is a high crop tractor also and it is original. Thanks, Dean.
Dean Thornton
01-10-2007 08:52:25
 Re: Ferguson F-40 hi crop in reply to Dean Thornton, 01-10-2007 08:46:29
The Ferguson F40 was only made 2 years, 1956 and 1957 then it switched to the Massey Ferguson 50, which was basically the same tractor.
mn.Chuck
01-10-2007 08:15:13
Mike, Don't recall the original Mystery Ferguson,
but a F-40 didn't come in a "Hi-Crop". If you look
at your s/n plate the s/n starts with 3 letters,
then 6 numbers. The first letter will tell you the
chassis type. S-Utility, R-twin wheel(narrow front)T-single wheel, C-hi arch(38 " tires) tho
the majority were utility, we sold and serviced
a small number of Hi-Arch. 5670 were built in 1956
and I don't have the total offhand on the 1957
production. They were mechanically the same as a
MH-50, then some changes,clutch,hyd pump etc, by
the MF 50's. Chuck
