mh44-6 distribtor question
simon boliin
01-09-2007 13:51:28
i have a mh44-6 distributor on a 226 continetal engine and i need a new rotor but no one at any of my local stores can find it all the ones they find have a huge hole on the bottom to fit on post in the dist but the one i need has a small post about 1/4 inch with a flat side any help would be great thank you in advance i will put up a picture soon
Randy Zandt
01-12-2007 17:20:56
 Re: mh44-6 distribtor question in reply to simon boliin, 01-09-2007 13:51:28
I live in Kalamazoo,MI. and had the same problem.I went to NAPA AUTO PARTS and they called their tech. center and got me the correct rotor,cap,points and condensor.Now all I need is the correct gap for my points
simonbollin
01-13-2007 16:41:10
 Re: mh44-6 distribtor question in reply to Randy Zandt, 01-12-2007 17:20:56
i tried that but the tech dept said with no distrib number they couldn't help the number all are gone thanks
massey333
01-09-2007 16:13:39
BAD news is there are a couple of 4 Cyl and a couple 6Cyl Auto-Lite(Presto) Dists.that you stand a 99.9% chance of NOT finding Caps or Rotors for.The Good news is you can still buy New Ones that fit.
simon bollin
01-09-2007 16:24:37
 Re: mh44-6 distribtor question in reply to massey333, 01-09-2007 16:13:39
do you know where to find a new one i would love to get something to work i want this tractor to work thank you simon
massey333
01-09-2007 17:29:41
 Re: mh44-6 distribtor question in reply to simon bollin, 01-09-2007 16:24:37
Check with a rebuilder if you can first. OR try Pertronix.com for Ind.App. or Montesequipment.com.for Cont.Parts,there are 1000s of those engines out there in Ind.App.We have found what we needed in other Applications.Good Luck.
CENTAUR
01-09-2007 14:57:45
Is it a AUTO-LITE or DELCO-REMY? What is the exact Distributor number? Someone may have the answer then.CENTAUR
simon bollin
01-09-2007 16:22:54
 Re: mh44-6 distribtor question in reply to CENTAUR, 01-09-2007 14:57:45
it's a autolite dist but the number plate is gone no numbers on the distributor
