Perkins Block 5/16 oil pan bolt stripped. Help!!
William Bos
01-09-2007 13:17:35
Hi,
We are finishing up a Perkins A3.152 diesel rebuild. I went to put on the oil pan bolts ( 5/16" NF ) , and I found out that one was drilled or stripped by the machine shop. ( out of business now. ) We ended up drilling it out to 3/8 NF as the original hole was probably drilled out and not tapped or something. The hole was too big for a 5/16" bolt.
Anyway, we tapped it to 3/8" NF, but when we go to tighten the bolt, the threads on the bolt get chewed off. How do we fix this? Heli coil kit?
Help please because I really don't want to have to take it to a machine shop for repair.
Thanks in advance ,
Will
Dean
01-10-2007 15:43:27
 Re: Perkins Block 5/16 oil pan bolt stripped. Hel in reply to William Bos, 01-09-2007 13:17:35
Hi, Will:
I agree with David. For the life of me, I do not know why MD used fine thread bolts into cast iron. Fine thread bolts have less thread engagement than course thread bolts and are not recommended for use in soft materials like cast iron.
If worst comes to worst, you can helicoil it. With patience, helicoils work well.
Dean
William Bos
01-09-2007 18:58:57
Hi David,
It is along the left side of the block, 2nd from ftont below the oil filter housing. We will try the 10mm course tap tomorrow.
Thanks,
Will
DavidP, South Wales
01-09-2007 15:37:05
Hi,
Is the damaged thread in one of the holes where the long bolts fit at the rear or along the side?
If you have pulled a 3/8 bolt out you might be able to tap a 10mm coarse (std) thread and get enough hold.
DavidP
