MH30 remove hydraulic lines
J Moff
01-08-2007 09:17:09
I want to remove the hydraulic cylinder and valves for rebuilding (located under the seat) but can't figure out how to disconnect the high pressure line. The low pressure line has one end of the hose fastened with a clamp over a nippled end so it can be disconnected and then threaded out from its elbow at the valve. But the high pressure line appears to be screwed into fittings on both ends. Is there a simple way to disconnect it. I do want to save both the hoses as they are in good shape.
