water pump replacement on Massey Harris 22
Trevor Morris
01-07-2007 11:53:49
Does anyone know if there's a water pump that one can use on a Massey 22 It's a Continental 4 cylinder gas engine with the distributor on top?
TGIN
01-08-2007 03:35:00
 Re: water pump replacement on Massey Harris 22 in reply to Trevor Morris, 01-07-2007 11:53:49
That would be a 140 cu.in. Like said before that eng. was used in alot of applications . NAPA can generaly get anything I need for mine .
J Schwiebert
01-07-2007 13:15:57
First of all that Continental was used in many applications. That means parts are easy to obtain. That also means there were several different water pumps. Unlike an automotive pump a water pump such as yours is usually rebuilt. You will need the casting numbers off the pump. More questions? J.
Trevor Morris
01-07-2007 13:48:29
 Re: water pump replacement on Massey Harris 22 in reply to J Schwiebert, 01-07-2007 13:15:57
I tried my local automotive supplier(LORDCO) THEY HAD nothing that matched my casting #s
brendan harty
01-10-2007 23:11:49
 Re: water pump replacement on Massey Harris 22 in reply to Trevor Morris, 01-07-2007 13:48:29
I have access to a water pump and front grill from a massey#102. Pump needs repairs but kits are available. It is good shape otherwise. Maybe this unit would help you out.
