pony hydraulic
John65
01-07-2007 05:57:46
Which line is the out line on the hyraulic pump and which is the in line on the cylinder?
Larry Martin
01-07-2007 09:38:01
 Re: pony hydraulic in reply to John65, 01-07-2007 05:57:46
John, the rear port that has an O-ring in it on the cylinder valve is the inlet. It is raining now and I will go out and look on the pump when it stops. I think it is the front port, but am not sure. I just made a new set of lines for mine but can't remember which one it was.
Sean Feeney 2
01-08-2007 05:19:20
 Re: pony hydraulic in reply to Larry Martin, 01-07-2007 09:38:01
Larry What type of tubing did you use for new lines ?
Larry Martin
01-08-2007 08:42:19
 Re: pony hydraulic in reply to Sean Feeney 2, 01-08-2007 05:19:20
3/8" OD steel tubing. The lines are brazed into the blocks on both ends. The tubing costs about $15.00. You will need a good bender.
