Perky Oil pan bolts torque specs??
William Bos
01-06-2007 13:39:01
Hi All,
What should the oil pan bolts be torqued to on a Perkins 3A152 diesel?
Thanks,
Will
William Bos
01-06-2007 14:44:31
 Re: Perky Oil pan bolts torque specs?? in reply to William Bos , 01-06-2007 13:39:01
Hi David,
Are these listed in a different MF manual than I have? ( I have Parts, & Workshop service manual?
Also, if you could, how much torque is required for the front mount to oil pan bolts?
Thanks,
Will
DavidP, South Wales
01-07-2007 12:42:24
 Re: Perky Oil pan bolts torque specs?? in reply to William Bos, 01-06-2007 14:44:31
Hi,
The figures for the sump are from MF info given on training course. A figure of 145 to 150 lbs is OK for the axle casting bolts. If you have a weight frame or anything else fitted to the front lower two long bolts, make sure you have adequate bolt length in the casting.
DavidP
DavidP, South Wales
01-06-2007 14:12:50
Hi,
22-23 lb-ft for the vertical 5/16 bolts into the block and 55 lb-ft for the horizontals into the gearbox casing.
DavodP
