starter ring gear
c hess
01-04-2007 12:31:19
Friend needs a starter ring gear for Massey Haris 33 . It is 12 in inside an has102 teeth. Call 937-935-4473(cell) or post message
c hess
01-05-2007 06:45:52
 Re: starter ring gear in reply to c hess, 01-04-2007 12:31:19
Thanks for reply. Owner has found a used replacment-Hope it is a good 0ne.
marlowe
01-04-2007 17:35:06
give it a little heat nock it off flip it over and put it back on they fit eather way unless that has been done allready
mn.Chuck
01-04-2007 17:11:38
p/n is 760020Ml. If you find one you will fall
over when you get the price. I'd go with msb and
give a rotation. If it won't tighten firmly enough
then give a few tacks of weld. Have seen that done
many times. Chuck
msb
01-04-2007 15:39:50
Tell him to heat it a bit and take it off.Give it a quarter turn and put it right back on.
