Well, I paid for it, now I just got to get it home! LinkIt looked solid. The guy did some top end work on it a year or so ago, new dist. and cam (worn out gears on it, was chewing up the dist. It smoked a little bit and had some blow-by but not much, and it mostly went away once it was warm. Loader and backhoe seemed to hold up on their own well enough, no noticable droop in the 15 min or so we were poking around and talking. He has some new front tires for it, I just need to get them on the rims. The power steering worked good. No noticable drips of oil from the trans drain where the cotterpin is. I didn't play with the 3pt or the PTO, both were hidden and boxed in with the backhoe. The loader has 102M on it, and the backhoe was made by Davis model 185 Any idea where I can find specs for those? It looked like the loader had been repaired on one arm in the past, but looked like a solid repair. The oil in the rear looked a little milky, he said it has in the past and he always changes it when it gets like that. So possibly a vent or a seal somewhere. We have had record rains here over the last 2 months, and even in the last 2 days it has been raining HARD with lots of good driving rain. So once that gets changed I will try and keep it covered. The only thing that was of a big concern for me was the brakes don't work. He says that they did, then it sat for a while, and now nothing happens when you step on the pedal. The pedal moves, and you can see everything moving on the back of the drum, but no stopping power happens. He things that something must just be frozen or what not. I might pull the wheel off and see what happens. Does anyone know where I can get (or if it is possible) to get some manuals for it? Stuff like brakes and such.... Also, can you guys tell me how/what all these leavers do. >Link and for the 3pt hitch I guess>Link I>Link like how simple it all is, and how easy it looks to fix.
