mf-35 may not be charging
ric1
01-01-2007 12:02:20
ihave a mf-35 english 3 cyl. perkins im getting good voltage from the generator anywhere from 8 volts at idle to 15 at high rpm at the battery post im getting a constant 12.6 trying to figure out if my battery is shot or its not charging correctly voltage reg. is about a year old battery seems to never have enough juice to start it unless its been running for a while.
Bob
01-01-2007 14:26:17
 Re: mf-35 may not be charging in reply to ric1, 01-01-2007 12:02:20
If the battery voltage is NOT coming up with the generator's output voltage, the "cutout" is not closing (defective cutout or voltage regulator), or the wiring connecting the generator to the voltage regulator, and on to the battery is "open" somewhere.
ric1
01-01-2007 14:28:09
 Re: mf-35 may not be charging in reply to Bob, 01-01-2007 14:26:17
thanks ill check that out tommorro
ric1
01-02-2007 08:01:01
 mf-35 now charging in reply to ric1, 01-01-2007 14:28:09
the feed side of the amp gauge was not getting a good connection
Bob
01-02-2007 21:39:12
 Re: mf-35 now charging in reply to ric1, 01-02-2007 08:01:01
That's GREAT news!
