Massey Ferguson MF34 loader MF54 backhoe
MF Operator
12-31-2006 18:39:26
I need to know if an MF34 loader and an MF54 backhoe off of an MF30 tractor will fit my MF245 tractor. If anyone can tell me I would greatly appreciate it. Thank you
135 Fan
01-01-2007 11:30:14
 Re: Massey Ferguson MF34 loader MF54 backhoe in reply to MF Operator, 12-31-2006 18:39:26
The MF 30 is closer to a 255 or 265 but still has a much stronger front axle. I think if you put the loader and hoe on a 245 you would be asking for trouble. The MF 34 is an excellent loader but is a lot heavier than a "farm loader". Just my opinion. Dave
GaryF
01-02-2007 00:44:07
 Re: Massey Ferguson MF34 loader MF54 backhoe in reply to 135 Fan, 01-01-2007 11:30:14
You would have to check that the bumper assembly will bolt up to your front casting and clears the hood etc. You would also need a different drive assembly (shaft and adaptor) for the hydraulic pump. Maybe also some fab as the 245 may not have provision to bolt hyd pump directly to the front casting.
It would most likely work however as Dave stated the front axle would be under considerable stress....unless your 245 is an Orchard model. Gary
