weight
ROBERT HOUSMAN
12-31-2006 06:27:09
Any ideas on what or how to put weight on front of TO35 Ferguson. Have fluid in front tires but need more.Live on lots of hills.Thanks
Aaron Ford
01-01-2007 01:58:04
 Re: weight in reply to ROBERT HOUSMAN, 12-31-2006 06:27:09
Most folks up my way use thick walled pipe and fabricate a front bumper. This protects the front of the tractor, provides a nice solid tow point, and provides the weight across the nose where it is needed. Scrap well casing and recovered natural gas piping are usually available. I have heard of melting lead wheel weights and pouring inside of said bumper, but I think that would be overkill. Your local welding shop should be able to fix you right up. HTH
Let's go Mountaineers,
Aaron
Rod in Smiths Falls, ON,
12-31-2006 14:17:27
Add a loader and you'll never complain about light steering again. (grin)
mf 188
12-31-2006 13:49:13
Hi,in the uk there was an optional weight frame for early mf 135 tractors that fits uk mf 35's , it will carry 8 x 60 lbs weight. Inner wheel weights are also another option these weigh 72 lbs,i hope this helps.
GaryF
12-31-2006 16:12:27
 Re: weight in reply to mf 188, 12-31-2006 13:49:13
Maybe my weights are 60lbs but man do they ever feel like 80lbs! Gary
GaryF
12-31-2006 06:44:17
Robert...There was an MF front weight bracket/bumper available for the MF135's I believe these will also fit the MF35's. It attaches with 4 bolts to the underside of the front casting. You would want to check bolt spacing to be sure as there may have been more than 1 bolt pattern for early/late tractors. The one on my 135 has 9x80lb MF weights on it. Gary
