MF1100 cab heater
Kevin Bismark
12-30-2006 21:53:18
Finally hooked the hoses up for the heater in the cab we put on last winter, it is circulating no air problems, insulated them well, but dont' seem to get much heat up there, have it hooked up to the 2 ports on the water pump, couldn't see any other way to hook up but not enough hot water up there was in the low 30's today when I tried it and just not enough heat, pulled the hoses off in the cab and it's circulating but not enought, the heater core is clear, this should circulate better, not sure about this water pump, say's it is supposed to circulate in the block some how and then to the radiator when the thermostat opens, thinking about trying a new thermostat in case that one just is stuck open a bit, the engine seemed a lot warmer than the hoses were to the cab, lucky it's not cold out yet, might have to try a small pump to help move it but thought it should move enough on it's own..
