1150 MF V8 perkins
willywonka
12-30-2006 13:11:56
Would it make a good puller
holm
01-02-2007 15:03:47
 Re: 1150 MF V8 perkins in reply to willywonka, 12-30-2006 13:11:56
I had a 1150 that I pulled back in the 80's.The weak point was the multipower.Once I learned when to shift it and when not to I didn't have many problems.As for power I could run in high 3rd,high multi power at 9000 lbs&high 2nd high MP at 12000lbs.This tractor was also used in the field doing heavy tillage with no problem.
Unclemerle
12-30-2006 15:09:48
Willy
One can make anything out of anything, however you have to remember the 510 ci. engine is rare and a 540 ci.(1155, 760,860 combine)engine is more common. Second; the rearend and tranny is shared with an 1100 and 1130, good combo but you will need a lot of spare parts. The 1150 wasn't one of Massey's better ideas.
Good luck
Merle
willywonka
12-31-2006 00:41:17
 Re: 1150 MF V8 perkins in reply to Unclemerle, 12-30-2006 15:09:48
Thanks Unclemerle Ill keep that in mind. What usually breaks? Parts in the trans or rearend?
Unclemerle
12-31-2006 05:58:38
 Re: 1150 MF V8 perkins in reply to willywonka, 12-31-2006 00:41:17
Willy
Trans will like to get stuck in park and we had problems in our 1130 with the ring gear spinning in the final drives. Our 1155 never has had this problem and our neighbors 1150 had this problem when he traded it many moons ago. Another friend had one of the first 1150's and it was in the shop more than in the field. If I was going to build a puller a 2805 would be on my list, you can't stop them.
Merle
willywonka
12-31-2006 08:26:08
 Re: 1150 MF V8 perkins in reply to Unclemerle, 12-31-2006 05:58:38
thanks for the info on the 1150. i think ill pass on it. the only reason was i considered it was i could have got it cheap. Thanks for saving me a headache
willywonka
12-30-2006 13:17:52
If so what is one not running worth? Thanks
dar440
01-03-2007 20:43:58
 Re: 1150 MF V8 perkins in reply to willywonka , 12-30-2006 13:17:52
Take a look at this site.
www.bootheelpullers.org
There are several Masseys pictured...including a 1150.
