Perkins 3-152 torque data
MF Pain
12-29-2006 03:55:26
Hi all,
I'm after head torque and valve clearances for a Perkins 3-152 if any one can help. Does any one know of any sites with this information available?
Thanks
Make mine a Massey
12-29-2006 07:01:57
 Re: Perkins 3-152 torque data in reply to MF Pain, 12-29-2006 03:55:26
I've got an original shop manual
Valve clearance is .070 - .140 below face
head torque is 55-60 ft lbs.
Gerald j.
12-29-2006 18:59:33
 Re: Perkins 3-152 torque data in reply to Make mine a Massey, 12-29-2006 07:01:57
That .07 to .140" clearance is clearance between the valve head and a straight edge across the head. Helps to set the diesel compression ratio. Its not the valve lash for setting the rocker arms.
My MF-135 I&T book says Perkins diesel 3 cylinder gets intake and exhaust set to .010" hot. Gas Perkins .012" intake, .015 exhaust, hot.
My MF-135 owners manual says .010 hot and .012 cold for the Perkins diesel. It doesn't cover the Perkins gas engine which means it fits my tractor that has a Z-145 Continental.
Gerald J.
