MH 22 Electrical Problem
waclar
12-28-2006 19:26:01
My dad just installed a new wiring harness and followed instructions, both with harness and Massey manual, but when he turns on the lights (engine not running) ammeter shows charge, not a discharge. Any suggestions?
Alberta Mike
12-29-2006 09:13:12
 Re: MH 22 Electrical Problem in reply to waclar, 12-28-2006 19:26:01
Happened to me once when I installed an ammeter with the needle's pivot point at the top of the gauge and the needle pivoted L-R along the bottom of the needle's arc. Reverse the wiring at the terminals in any case (this type of ammeter or the usual type) and it should read properly.
matt720
12-28-2006 19:39:03
just a possibility, but the leeds on the ampmeter may be reversed or if the battery is installed backwards,reversed pollarity, it will also make the meter show charge instead of discharge. it should be positive ground.
