massey1080
miplntman
12-26-2006 08:53:27
What is a 1080 Massey with one rear tire flat the other is baddly weather checked, one flat front, one brand new, a cab has a wood top and is rusty, That runs and drives(with new tires on it)good, WORTH???? Oh yea and the nose cone is smashed and the front and back windows are plexiglass and the right top window is smashed out.
ErnieDD
12-27-2006 16:41:21
 Re: massey1080 in reply to miplntman, 12-26-2006 08:53:27
Neighbor had 1080, 1100, and 1130. The 1080 was a long ways of being anything close to the other two in tractive effort alone. I would pass.
Unclemerle
12-27-2006 17:54:54
 Re: massey1080 in reply to ErnieDD, 12-27-2006 16:41:21
Ernie is correct in that the 1080 does have it's limitations. However it does have it's place in some operations and maybe yours. We have a 1080 and 1130 with loaders on them and a 1155 plus a few more. You use the right tractor for the task and maybe the 1080 will fit your task/operation.
If you can pick it up for a $1000 or less it's a great deal, $1500 or less good deal, $2000 or less soso of a deal.
Take Care
Merle
MC in KY
12-27-2006 05:49:11
I have to agree with Unclemerle... $2500 to $3000 max is all a tractor like you described is worth in KY. It will cost you several thousand dollars to fix that one up...
Unclemerle
12-27-2006 03:56:13
In SWMN $2500 max. Tires alone will cost you $1000 if you put on new.
Good luck
Merle
