Massey Harris 30
heybusdriver
12-25-2006 11:10:46
Did the Massey Harris 30 have a fuel reserve or was it only the Massey Harris 30K that was equipped with this option? If it did have this option , how did it work?, My tractor is a regular 30, the sediment bowl may not be orginal but don"t know what an orginal looks like , if any-one could send me a picture of an orginal off a regular 30 would be appreciated , @ [email protected] thanks Stan
Jason1(Pa.)
12-26-2006 10:44:53
 Re: Massey Harris 30 in reply to heybusdriver, 12-25-2006 11:10:46
I helped my neighbor fix up his 30 not long ago. Everything on it seems to be original and in very good shape. The sediment bowl however is the type that doesn't have the reserve. Thats not saying much,but like I said this tractor didn't have much changed and the sediment bowl looked old enough to be original. I don't see why you couldn't put one in though. I know what you mean. I have two Fords and that reserve has saved me more then once when you way away from home working.
RandyN
12-25-2006 13:48:05
I don't know off hand if MH used that type of fuel bowls, but to have one on could be no surprise since the threads are all the same. I like them because they have the pipe that comes up inside a screen and they help to keep little rust flakes from getting to the carb.
RandyN
MMB
12-25-2006 11:34:04
By fuel reserve, do you mean two tanks? One for distillate fuel and the other for gasoline (used for starting)? If it was an original distillate model, the serial number should indicate 30K as opposed to 30 G for the gas model. I would guess only the 30K would have the two tanks (or the reserve that i think you might be referring to).
heybusdriver
12-25-2006 12:26:20
 Re: Massey Harris 30 in reply to MMB, 12-25-2006 11:34:04
What I was referring to , is I have a Ford 8N and by opening the valve more than two turns lets the reserve amount of gas flow through the sediment bowl, I assumed maybe other makes of tractors had similar reserves. When my Massey runs out of gas and I measure the tank there is about 1 inch left in the tank that does not come out, but I may not have the orginal sediment bowl,& some-one stole my serial number on the tractor but the serial number on the motor is still there indcates 162G. thanks Stan
MMB
12-25-2006 13:02:30
 Re: Massey Harris 30 in reply to heybusdriver, 12-25-2006 12:26:20
OK, I get it, sort of like the reserve gasoline in a motorcycle tank (or on the old Volkswagens from the 50's and early 60's which didn't even have a gas gauge). I did not realize there were fuel shut off/sediment bowl assemblies with this feature. I have seen sediment bowls that had a stem that positioned up into the tank and drew off gas from say 3/4" into the tank which left the crud and other stuff at the bottom and it wasn't accessible to the fuel line through the valve.
