battery for mf-35 diesel
ric1
12-25-2006 07:16:33
hi everyone i have a mf-35 diesel with the 3cyl. perkins. im going to replace the battery but want to make sure i get the right one as for cranking amps the one i have now works great in warm weather but soon as it gets cold it will hardley turn it over at all tired of jumping it and all that crap thanks ```````RICK
Dean
12-25-2006 10:50:17
 Re: battery for mf-35 diesel in reply to ric1, 12-25-2006 07:16:33
Hi, Rick.
I replaced the batteries in both of my MF-35s with Perkins diesel engines this fall. I installed 950 CCA batteries made by Exide from TSC. If you wait until they have a sale or special you can get them for about $90.00. Do not buy the similarly sized 750 CCA battery. One of my 35s had this battery in it when I bought it. There is a major difference in cranking speed.
I also replaced both battery cables with new 00 gauge cables. Propoerly sized battery cables are very important for cold weather starting.
Both crank very quickly now and will start below 30 degrees F without the use of the block heaters if I use the (functional) preheaters. If we get some cold weather this winter I will determine in what temperature I can start them using the (again functional) block heaters.
Dean
