1130 only steers to the right
npuller
12-24-2006 17:42:25
hi all frind has a 1130 that only steers to the right. it will not go left.it was working good then was parked for 6 months. hydrostatic steering is not my cup of tea.any help would be great.
barnrat
12-25-2006 04:40:34
 Re: 1130 only steers to the right in reply to npuller, 12-24-2006 17:42:25
Probably your Orbitrol(under steereing wheel) has gone bad and needs to be rebuilt,one of the springs may have broke or a valve is sticking. Kits are still available to rebuild these from your Agco dealer or hydraulic supplier. You can also buy a remaned one. These are kind of a bugger to remove, but can be sone without loosing too much blood.
Drill
12-25-2006 23:00:51
 Re: 1130 only steers to the right in reply to barnrat, 12-25-2006 04:40:34
Before getting too carried away with taking things apart check the telescoping feature right in the middle of the steering wheel. You can loosen the center of the steering whell and adjust the wheel position. The one on my 1100 was full of dirt and worn out from years of vibrations till the top shaft would turn but the orbit motor would slip, same problem only turn one direction.
npuller
12-27-2006 18:36:12
 Re: 1130 only steers to the right in reply to Drill, 12-25-2006 23:00:51
thanks drill
npuller
12-25-2006 08:41:38
thanks barnrat i will look at that.
