oil/wiring
eric g
12-20-2006 20:13:05
im am working on my mf 65 gas with what i think has about 2800 hrs on it i am not touchig the motor , or any other part of the drive train, it was in beautiful shape before i started, it has multipower. every thing worked great. should i be concernd about any major unseen nightmares? anyway is there a better oil that i can run other than sae.30, and what should i run in the rearend,trans,and outer planitaries. and where may i find a wiring harnes. thanks for the help!
jrsn
12-21-2006 10:09:51
 Re: oil/wiring in reply to eric g, 12-20-2006 20:13:05
Eric , The site below has harnesses. I see 65 gas listed as available. Ray s
http://www.wiringharnesses.com/
Aaron Ford
12-21-2006 07:45:31
The local Massey dealer suggested PermaTrans in mine. Seemed to think the 80-90w would be a problem in the cold. I do not think the synthetics were affected by the mandated removal of ZDDP. There should be no problem running synthetics. However, if it's dino sauce you plan to use, stick with the CL-4/CL-4+ grade diesel oils. I am sure you have been following the oil discussion here, so I won't repeat it. I am not sure if there is a wiring harness available for your 65. However here is a link to Big Deans website. This is for a gasser with a generator. He has wiring diagrams for models even with alternators.
Link
Eric in IL
12-21-2006 06:06:54
It sounds like you have a fine tractor that should provide years of good service if timely attention is given to its maintenance in the future. The 65 I have now is the same one I learned to drive in the mid 1960"s.
In my opinion you should check the condition of the front axle pivot bushings. The main bushing has a fairly thin wall (about 1/16 inch) and could need replacement with the hours you mention. If caught in time it is not a big job, but let go it can run into some dollars at the machine shop. This check becomes more important if your tractor was ever fitted with a front loader.
Engine oil? How much do you think of your engine?
How much are you willing to pay for the oil? I use synthetic 10W40. It costs alot. But I am the one that invested my time and money to overhaul my engine a few years ago. So I guess it is easier for me to justify the added cost for a synthetic oil. If your engine has any oil leaks I wouldn"t advise synthetic, it will leak worse with synthetic oil.
I use the current version of Permatran (I think it is Permatran III) in the trans./rear end. I get it from the local Massey dealer. It makes the hydraulics work much faster than the oil your owners manual suggests.
In the planetaties I use a 90 weight gear oil with Lucas oil stabilizer added. I run the oil level here at the top of the check hole. You will most likely not have a problem running the oil level at the bottom of the check hole UNLESS you use the tractor on a plow. With the left wheel on the higher, unplowed ground the outer seal will starve for oil and eventually leak. So if you are going to plow much just put in a little extra oil so the seals will get lube.
Just a few ideas for you to consider, I hope one or two will help you to enjoy your tractor as much as I enjoy mine.
in sticks
12-21-2006 04:38:46
a lot of discussion on oil lately.seems that newr oil wont do an older engine much good.they? say you should run rotella or something thats for the diesel engines
