MF 180 Hydraulic Problem
ramero
12-20-2006 04:38:59
I have a MF180 just bought. I am getting only 500 lbs pressure to the rams. Iam a newbie with this but have been reading the shop manual and before i take the tractor apart any suggestions on what the problem might be.
marty g.
12-20-2006 05:19:46
 Re: MF 180 Hydraulic Problem in reply to ramero, 12-20-2006 04:38:59
Firstly, add 10 liters of hydraulic fluid above the top mark on your gauge. After that tell us your pressure reading. The american made 180 has a tendency to suck air due to their setup after age took effect.
ramero
12-20-2006 05:25:24
 Re: MF 180 Hydraulic Problem in reply to marty g., 12-20-2006 05:19:46
have added more hydraulic fluid by mistake and 400-500 is all i get with motor reved up
marty g.
12-20-2006 07:34:15
 Re: MF 180 Hydraulic Problem in reply to ramero, 12-20-2006 05:25:24
Do you have the valves under seat from factory, first step would be to find a pressure relief valve. If it the factory setup, the relief valve is attached to the auxiliary pump. So you must remove the 3 pth cover to access this area.
