tach cable to alternator
michael truffa
12-19-2006 19:25:38
Just got a TO35 and replaced the alternator that was on it. During my refab I realized that there was not a tach cable. Ordered on but according to the parts manual it hooks to a gear that attaches to the generator. How do I attached the cable to a alternator. is there a way to modify a alternator to accenpt the tach cable or is there a way to hook up the cable differently??
Gerald J.
12-19-2006 20:56:45
 Re: tach cable to alternator in reply to michael truffa, 12-19-2006 19:25:38
You have to have the gears both the adjust the calibration and to reverse the rotation of the tachometer shaft.
I've had fine results with my MF-135 generator, so I'm not changing to an alternator.
It would probably be easier to make up a friction drive with a wedge shaped rubber wheel that could be driven by the alternator pulley from underneath, though I have no idea what the size would need to be. The alternator would benefit from using a smaller diameter pulley than the generator had so it spins faster.
Gerald J.
Aaron Ford
12-19-2006 20:23:25
I am currently in that situation myself. I guess it would be possible to tap the alternator shaft and install the drive gear. Then tap three holes in the back and secure the gearbox to the alternator. A longer cable and a correct sized alternator pulley would be needed. There was a company doing it, but I think they quit. I have not seen the listing on eBay for quite some time.
I decided to go a different route. I found a VDO tach that has an integral hourmeter for $113 at egauges dot com. I am replacing all my gauges with VDO Series 1 to match the tach. It's not stock, but many things are not going to be...
Let's go Mountaineers,
Aaron
