M.F. 65 diesel steering problem
S.R.Stump
12-18-2006 15:12:20
My M.F.65 steers real hard. I have checked the pump,hyd. cylinder & hoses with no success. Any help in solving this problem would be appreciated.
Aaron Ford
12-19-2006 07:25:21
 Re: M.F. 65 diesel steering problem in reply to S.R.Stump, 12-18-2006 15:12:20
You have likely already checked this, but the turnbuckle adjustment wears at the roll pin holes on the ends. The end result is that the control valve never gets actuated. It normally starts happening on one side prior to the other. There should be a small amount of play here, but not excessive.
Pump pressure might also be checked...HTH
Let's go Mountaineers,
Aaron
