arron ford/135 fan/big dean
phil25
12-18-2006 03:37:03
Good Day: I had asked previous about a 135 diesel
leaking out engine oil out of the "welch" plug at rear of the block and with very high oil pressure,also a bouncing neddle on the pressure gauge.
Just to up date a bit, took the engine into the shop to check for a rolled bearing, instead we found a stuck oil pump relief valve hence 85lbs plus of pressure. All is back together and owner drove away happy with 63 lbs and a steady neddle on the gauge.
Again thanks for the reply[s]and help, very much appreciated.
Aaron Ford
12-18-2006 14:18:37
 Re: arron ford/135 fan/big dean in reply to phil25, 12-18-2006 03:37:03
I nailed it!!! That's rare... Glad you found out what the problem was. After reassembling mine, I recall the welch plug you speak of. It fills the end-hole where the oil galley was drilled. 85 psi, wow. Better to have too much than not enough. Had to be hard on the pump, though.
I have oil pumped to the top of my block. Just waiting for the front support to get back from the machine shop so I have something to bolt a radiator to. I am dying to start this thing.
I overfilled my belly by a large margin, but that's to be expected. I still have to install my standpipe, so I will pump it out then.
Anyway, glad it was a cheap (relative) fix.
Let's go Mountaineers,
Aaron
