Pony Timing
Joel59
12-15-2006 17:42:19
Can someone please explain how to set the timing on a Massey Harris Pony tractor? (in detail) I had to install a new camshaft and now the timing is nowhere even close. The motor is still out of the tractor with the head off. Thanks.
cam2
12-19-2006 19:13:36
 Re: Pony Timing in reply to Joel59, 12-15-2006 17:42:19
have a pony as well, timing marks should not wear off of your crank or cam gears, do remember on mine belive it or not one of the dots were astamped on the wrong side;dont remember which it was the crank or the cam.line them up rotate engine 360 degrees and they should line up again.put motor together and back in tractor,the distributors the last thing to go on,because your probly going to have to turn crank to line up with the clutch plate,then put distributor in,dontalways trust your tdc point with the mark you made on your crank use your rule of thumb,thats right put your thunb in number one.
Larry Martin
12-17-2006 14:57:38
You will two punch marks on the crank gear and one punch mark on the cam gear. Punch mark on cam gear goes between the two punch marks on the crank gear.
Joel59
12-18-2006 17:18:04
 Re: Pony Timing in reply to Larry Martin, 12-17-2006 14:57:38
Thanks guys. I got the cam timing straightened out with the punch marks. Now for the ignition timing. I put the #1 cylinder on TDC of Compression stroke and lined up the rotor with the #1 plug wire. How do I know where the other 3 wires go? Thanks.
Larry Martin
12-19-2006 16:06:16
 Re: Pony Timing in reply to Joel59, 12-18-2006 17:18:04
Firing order is 1-3-4-2. Distributer rotates clockwise.
Bob
12-15-2006 19:48:27
Cam timing, or ignition timing?
If cam timing, were the gears clearly marked?
Joel59
12-16-2006 05:42:20
 Re: Pony Timing in reply to Bob, 12-15-2006 19:48:27
Don't think the gears are marked. Will need both eventually. Thanks.
Bob
12-16-2006 21:36:25
 Re: Pony Timing in reply to Joel59, 12-16-2006 05:42:20
Sorry, "pulling" the shop manual was on my "to do" list today, but I never got that far down the list!
