I did not see your prior post, so I will attempt to answer now. You wrote: "WHY TEAR DOWN SO FAR, WAS EVERYTHING SHOT OR ARE YOU JUST GOING THROUGH EVERYTING? and watch the paint dont buy the the cheapest sh-- out there I spent 200 on my paint, 100 per quart and it is awesome it is from PPG. thats with hardener,ETC." The answer is yes and yes. I was going to go through everything, and found everything shot in the process. I am currently hemmoraging cash at a rate that is alarming the spouse. My body man picked the paint, so I am not sure what he used on the tin. Looks great, though. I will be using Omni (from PPG) on the chassis as it is $67 a gallon while the PPG is $193. I plan to lay several coats, so it should not be a problem. The primer is Omni high build over Rustoleum Red Oxide Epoxy Heavy Rust. I am using it due to the fact that it seems to adhere well and shows what has been primered. With grey primer, I have difficulty discerning what has been painted and what is bare metal. It looks great till three days later and it begins to surface rust. I am several months away from any real painting, but that is the next big project after I get the front support bolted back on. It is currently at the machine shop getting the pivot rebuilt. More cash.... Let's go Mountaineers, Aaron
