mf 65 hp/hours
eric g
12-10-2006 18:20:56
how many hp is my 1962 mf 65 gas multi-power rated at., and what is the life of that engine, I have 2500 hours on mine i dont think i need to tear it down i figure it to be at most the half life of that engine. any thuoghs?; thanks, eric from MN
NEsota
12-11-2006 15:35:36
 Re: mf 65 hp/hours in reply to eric g, 12-10-2006 18:20:56
I bought S/N SMG 653116 (1959 model I think), in Minnesota about 4 years ago. The tack showed 2100 something and I did not believe it. The brakes held very little. When those were repaired we found what could be original brake disks, with almost no wear. The reason they did not work well was because they had been in contact with the metal surface for so long without moving, that the fiber bonded to the metal and then when things were moved the fiber brake material stuck to the metal and became glazzed. This is my opinion and was my first experience with disk brakes on a tractor. This tractor came with a loader and bucket of the kind people use to pile snow. The only place on the tractor that I have found any real wear is in the clutch foot pedal arm. At the foot pad end of it you can move it in and out a fraction of an inch from the housing. The unit did not have power steering and would have been awful to move snow with. So�.
I am wondering if it possible that this unit did just sit around waiting to move snow and it never happened. Opinions from the forum about what to look for as clues to the real hours are most welcome.
Tom671
12-11-2006 04:31:26
I wish I had your luck
Aaron Ford
12-10-2006 18:36:11
My Massey manual lists the engine power at
52HP@2000
155LB/FT@1150-1250
Nebraska Test: Test Number: 659 Test Date: June 1958 Engine: gasoline PTO HP: 46.1 Drawbar HP: 41.6
The hours on the proofmeter are dependent on the proofmeter having worked for the last 45 years. If you have a known history on the machine you are much better off.
For example, my 65 is about to have zero hours! Everything was trashed and I am doing a resto/refit. The proofmeter died many years ago.
HTH
Lets go Mountaineers
Aaron
ERIC G
12-10-2006 18:57:07
 Re: mf 65 hp/hours in reply to Aaron Ford, 12-10-2006 18:36:11
THANK YOU FOR THE INFO, MY MF 65 WAS IN BEAUTIFUL SHAPE BEFORE I STRIPED HER, NOT HARELEY A DING IN HER, WHAT A FIND!, JUST WANTED TO PUT A NEW COAT ON HER. I THINK THE HOUR METER IS DANG CLOSE JUDGEING BY THE SHAPE OF HER
