Leaky Oil Filter Canister Top Lid Bolt
KCTractors
12-09-2006 21:29:18
Was doing a favor for neighbor to change oil and filter on a Massey 33, I cannot get the bolt on top of the canister ( between cover and bolt) to stop leaking. The parts book does not show any gasket in between the bolt and cover, also no way to get one in there. What do I do?
KCTractors
12-17-2006 10:36:04
 Re: Leaky Oil Filter Canister Top Lid Bolt in reply to KCTractors, 12-09-2006 21:29:18
Just a follow-up on the problem, I just but a O-ring under the bolthead, worked fine. Thanks
marlowe
12-10-2006 12:44:12
oem had a soft copper washer. just clean it up and put some RTV around the bolt just under the head that seals them just fine
Joe Ferguson
12-10-2006 08:23:20
Hi KC
There are (sometimes) a rubber washer each end of the
old cartridge you may remove one gently with pliers
if not damaged you may use it as bolt washer-seal.
I done that several times in the past and worked well
My 2�
Joe Ferguson
BigMarv1085
12-10-2006 06:37:56
You should be able to go to a parts store and get a crush washer to fit between the two and tighten it up.
