weight of a MF135 and bush hog?
Rusty Stuff
12-09-2006 10:53:13
Finally was able to make a deal on a MF135, been trying for awhile. Anyway does anyone know what a MF135 with the 4 cylinder continental engine weighs? It also has a 5 foot bush hog on it and I am trying to figure if my car trailer will handle it. Thanks!
Aaron Ford
12-10-2006 18:46:12
 Re: weight of a MF135 and bush hog? in reply to Rusty Stuff, 12-09-2006 10:53:13
third party image
If your trailer won't haul it, I know of one that will....
Let's go Mountaineers
Aaron
phil(va)
12-09-2006 20:23:03
The two together will be at least 4,000 lbs, probably a little more. Trailer itself probably weighs at least 1,000 lbs, so you will be pulling over 5,000 lbs, but probably less than 6,000.
in sticks
12-09-2006 17:28:47
you should also check to see if tires are loaded
rusty stuff
12-09-2006 18:38:06
 Re: weight of a MF135 and bush hog? in reply to in sticks, 12-09-2006 17:28:47
yes the tires are loaded, how much does that add?
Gerald J.
12-09-2006 19:23:09
 Re: weight of a MF135 and bush hog? in reply to rusty stuff, 12-09-2006 18:38:06
If 14.9-24 and 70% full with CaCl, about 650 pounds per tire.
Gerald J.
