I have inherited front end loader and would very much like to know more about it in order to discuss maintenance, etc. However, I first need to know what it is.There is a Massey Ferguson tag on the left �heavy duty upper arm� of the front end loader. (pardon all my na�ve descriptions). It denotes the following: MF 34, then underneath in Black : L8110, next to that is 10150. About knee high on the left side of the dash is What appears to be a 9 or 9A 201448. Along with a lot of patent information. There is another tag on the left side of the engine area: Perkins Lucas Cav; Serial No. 27133JKG, also DES: 323OF240. These are all of the Aluminum tagged info that I have been able to find. All the other numbers appear to be part numbers for the individual pieces making up the tractor. There is also a big heavy steel rectangular box like thing with a blade that appears to attach to the rear of the tractor as well as a big mower attachment. There is a steel canopy over this diesel tractor and it has hydraulic levers on the back right side as well as the front right for the arms and bucket. There are two shift arms on the floor below the dash and one appears to be a low and high and the other is some other gear shifter. The left foot is a brake. The right has a three pronged shift the left prong is forward, the center is neutral and the right is reverse. I don�t need to shift really. When I try to look up information on this I usually come up with MF35�s so I am not sure if this is a hybrid of the MF35. I also don�t know if this is an industrial tractor or not. It sure seems like it would be. Can someone help me determine what this is. I am going to take a picture soon. That would certainly help, but I am hoping that the above numbers will do the trick. Thank you very much, Michael
