Power steering problems with an MF 165
TAB
08-24-2000 21:40:15
My father has an MF 165 which he doesn't use on a regular basis, but the power steering has worked fine up until now. He describes the situation as follows: When he starts the tractor cold, the power steering works fine for about 2 or 3 minutes, after which it gets herky jerky and then hard to steer. He says he can shut the tractor off, then immediately start it again and the power steering works fine for about 30 seconds and then the process starts over again. He has changed the power steering fluid and fluid level is normal. He says that, after running the tractor a few minutes, the fluid seems a bit foamy. Any ideas? Thanks in advance!
