175 Hydraulics for Loader
strev1971
12-02-2006 18:31:39
I recently purchased a 175 that has only a single hydraulic control valve for the loader. Is it possible to put a double control on and if so where might I find one.
135 Fan
12-02-2006 21:41:27
 Re: 175 Hydraulics for Loader in reply to strev1971, 12-02-2006 18:31:39
Yes. You can get a valve at any good hydraulics outlet. A two spool with float for the lift is best. You could put a three spool on so you could have an extra valve for a grapple fork or rear hydraulics while the loader is hooked up. If your existing valve is factory you can probably lock it in position and use it to pump oil to the new valve. My tractor is set up this way. You need an open center valve. Hope this helps. A dealer could give you info as well. Dave
