165 diesel engine oil
ric1
12-01-2006 02:19:09
just got a 165 diesel what engine oil/grade does it take. thanks
jicarre
12-01-2006 10:33:05
 Re: 165 diesel engine oil in reply to ric1, 12-01-2006 02:19:09
Hi RIC 1,
I had the same question for the next maintenance of FIRMIN (my MF165) ? Thank you everybody !
How many oil liters in the engine ?
Don-Wi
12-01-2006 11:14:16
 Re: 165 diesel engine oil in reply to jicarre, 12-01-2006 10:33:05
We run 15w-40 in all of our tractors, including our 165 gas (continental engine) It holds 6 quarts w/ filter. The manual says the deisel (perkins) holds 7 1/2 qt, or 8 1/2 w/ filter.
Donovan from Wisconsin
Aaron Ford
12-01-2006 09:24:42
I think everyone is using the 15w-40. Due to the fed mandating the removal of key antifriction additives in gasoline oils, owners of older gas engines are also making the switch due to the increased failure rate of flat tappets with the new oils.
HTH Aaron
cobblehillfarm
12-02-2006 13:16:38
 Re: 165 diesel engine oil in reply to Aaron Ford, 12-01-2006 09:24:42
Aaron..please tell us more about the change to oils (why, what effect does it have,) and what the soloutions are. Thanks Kevin.
Charlie in VA
12-01-2006 06:14:35
Ricl, I use Shell Rotella T 15W-40 Heavy Duty oil in my MF 165 dsl.
Charlie
