mf 30 differential lock in help identify photos
Merlin W. Phill
11-28-2006 17:46:40
Jon,
The strange two headed bolt is the actual differential lock bar. The lock moves in to lock the differential.
Things to check
1. remove the actuator arm
2. remove the cast actuator part and clean all rotating surfaces
3. see if you can move the "two headed bolt" in
if the actuator rod moves, then the rest of the unit should be simple to get working. Otherwise, it may take a trip into the interior of your rear end.
V/R
Merlin
