3-Point Problem
T L Nervig
11-27-2006 08:18:30
My 3-point won't lower. Can anyone give me a hint as to how difficult this is to fix. I believe the manual stated that it may be a bad spring.
Tractor-parts-guy
11-27-2006 08:43:09
 Re: 3-Point Problem in reply to T L Nervig, 11-27-2006 08:18:30
probably your unloading valve is stuck. How long has it been since the hydraulic oil has been changed? I"ve seen the old Fords with hyd. oil that I swear hasn"t been changed since they were new. You should see the crud and water accumulated and neither seems to act as a very good lubricant.
Ron
T L Nervig
11-27-2006 09:55:06
 Re: 3-Point Problem in reply to Tractor-parts-guy, 11-27-2006 08:43:09
I has probably been quite some time. I do have new to replace. If I completely drain and refill should that help with the problem if the valve is just stuck? and if that doesn't fix what are my other options.
tlnervig
11-27-2006 08:19:57
 Re: 3-Point Problem - Update in reply to T L Nervig, 11-27-2006 08:18:30
I have a MF201.
